Impulse Response in simple AR
strugglingeconomist
Postby strugglingeconomist » Tue Apr 03, 2012 4:15 pm
I am trying to find strucutral breaks in inflation series via a simple AR(6) process. I am not using VAR but would still like to do impluse response analysis. Is this in anyway possible in eviews?
I'd really really appreciate any help.
Thank you..
Re: Impulse Response in simple AR
Postby startz » Tue Apr 03, 2012 4:28 pm
I'm not sure what this has to do with a structural break, but if you estimate an AR model and choose View/ARMA structure you can see the impulse response.
strugglingeconomist
Postby strugglingeconomist » Sat Apr 07, 2012 2:42 pm
Hi!
Sorry for the late reply. I wasn't informed that you had replied to my query.
I did View/ARMA structure but the error msg said: "Equation does not have ARMA terms" (I figured because it had only AR terms.. :?: )
ps: the structural break comment was a miserably sad attempt to give you some background to what I am trying to do, which is: econometrics on inflation dynamics - so persistence, structural breaks and impulse responses on inflation series (if I can manage the last one)... Can I? Please please say yes.
Postby startz » Sat Apr 07, 2012 3:51 pm
Just AR models work fine, but you have to use the AR psuedo-variable. For example, if you have an AR(2) model
ls y c ar(1) ar(2)
Alternatively, you can set up a VAR with only one endogenous variable.
strugglingeconomist
Postby strugglingeconomist » Mon Apr 09, 2012 1:21 pm
I am not sure how you set up a VAR with only one variable. But I just did the method you described and it worked perfectly! Thank you so much
Though I didn't understand what was "1s" in the beginning...? o.O
Postby startz » Mon Apr 09, 2012 2:34 pm
"LS" if used at the command line.
