I want to create vertical lines on the x-axis for several data points, e.g. here in stata:
http://www.ats.ucla.edu/stat/stata/exam ... ta5_17.gif
How does it work in EViews?
Also, I want to write some short text on the line. How can I make the text vertical as well?
Thank you!
Graph
Re: Graph
Right click on the graph and select add lines, then right click on the graph and select add text.
