Dear all,
Is it possible in EViews (7) in a system to grab the residuals from one of the equations and use them in another (equation of that system)? (and how?)
I have a rational expectaions model in which I want to use the one step ahead prediction errors of one equation (=its residuals from one period ahead) as regressors in one of the other equations. Something like:
(eq1) Ft = a + bXt+ ERRORt
(eq2) Zt = c + ... + dERRORt+1 + ...
I hope that's clear enough...
Thanks and best regards
3sls / joint estimation: residuals
Re: 3sls / joint estimation: residuals
No, that's not possible in a system. Of course if the only interaction between the two equations is through that residual series, you could always estimate them as separate equations. I presume that your choice of 3SLS means this is not the case though :(
Thanks Gareth. Your presumtion is right. I have a joint determination of coefficients in the system. Well, it's unfortunate that Eviews does not allow something like this. Maybe in a future version?
CHR
CHR
You could manually put the residuals in:
(eq2) Zt = c + ... + (Ft+1 - a - bXt+1) + ...
