Precision control for table.save
Ravi
Postby Ravi » Fri Feb 10, 2012 4:04 am
Hi folks,
I am searching for a mechanism to control precesion of numeric values when I execute
table.save temp.csv
I searched and found some option in wfsave, but I want to save just a single table object and not the entire workfile
Any help will be appreciated
Re: Precision control for table.save
Postby EViews Jason » Fri Feb 10, 2012 8:33 am
You can save using full precision via the 'f' option. For example,
mytable.save(f) myfile 'save mytable to a csv file named myfile.csv with full precision
If you want to specify the precision, change the precision for all your cells in the table using the table 'setformat' command and then save. For example,
mytable.setformat(@all) g.5 ' change formatting in all the cells in table to use 5 significant digits
Ravi
Postby Ravi » Fri Feb 17, 2012 3:50 am
Thanks Jason.
Your suggestion worked fine
