I am having trouble establishing a link from Eviews to Access.
Dim cmdpat As ADODB.Connection
Dim cmdGetDB As ADODB.Command
Dim cmdDBParam As ADODB.Parameter
Dim rst As ADODB.Recordset
Dim eviewsstr, connstr As String
On Error GoTo ErrorHandler
Set cmdpat = New ADODB.Connection
connstr = "Provider=EviewsOleDbProvider.EviewsProv;" & _
"Path=c:\recessions.wf1; Include ID Series=False"
cmdpat.Open connstr
Set cmdGetDB = New ADODB.Command
Set cmdGetDB.ActiveConnection = cmdpat
eviewsstr = "@date gdpr_1 @smpl @all"
cmdGetDB.CommandText = eviewsstr
Set rst = cmdGetDB.Execute()
The eviewsstr takes on a value of 188 when I run the program but the recordset always turns up empty. Any help would be appreciated.
Thanks!
Eviews to Access
Re: Eviews to Access
I tried to do the same thing on my own workfile and it seemed to work fine. I assume gdpr_1 is a series?
Here's my code (written for VB.NET using Visual Studio 2008 and Microsoft ActiveX Data Objects 2.8 ) :
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
connstr = "Provider=EViewsOleDbProvider.EViewsProv;" & _
"Path=c:\files\tq.wf1; Include ID Series=False"
cmdpat.Open(connstr)
eviewsstr = "@date gdpf @smpl @all"
Dim liCount As Integer = 0
Dim lsData As String = ""
While Not rst.EOF
liCount += 1
For Each fld As ADODB.Field In rst.Fields
lsData = lsData & fld.Value & vbTab
Next
rst.MoveNext()
lsData = lsData & vbCrLf
End While
MsgBox(lsData)
cmdpat.Close()
End Sub
Just did the same thing in Access 2007 (using Microsoft ActiveX Data Objects 2.8 ) :
Option Compare Database
Public Sub test()
cmdpat.Open connstr
liCount = 0
lsData = ""
While Not rst.EOF
liCount = liCount + 1
For i = 0 To rst.Fields.Count - 1
lsData = lsData & rst.Fields(i).Value & vbTab
Next
rst.MoveNext
Wend
MsgBox lsData
cmdpat.Close
End Sub
