Principal component analysis on a matrix
PMaier
Postby PMaier » Wed Feb 01, 2012 1:06 pm
I'd like to use principal component analysis on a matrix and retrieve the scores.
I can use
matrixname.pcomp(eigval=v1, eigvec=m1)
to calculate the eigenvalues and eigenvectors, but there doesn't seem to be a command to calculate the scores -- although when I use the dialog box, I can store them in a series, so the capability is there.
Put differently, if my matrix were a group object, I'd use
groupname.makepcomp
and I'm assuming that there is a similar command for matrices, too?
Many thanks, Philipp
Re: Principal component analysis on a matrix
Postby EViews Gareth » Wed Feb 01, 2012 2:32 pm
matrix.makepcomp(score=myname) 3
saves the first 3 scores in a matrix called myname.
Postby EViews Glenn » Wed Feb 01, 2012 2:39 pm
The reason for the difference is that the matrices are not generally the same size as a workfile so that the scores can't be put into a set of series as in the group case. Thus, we allow you to save them into a matrix.
PMaier
Postby PMaier » Wed Feb 01, 2012 2:47 pm
Gareth,
You made my day.
Philipp
PS I don't think it's in the manual -- if that's correct, it might be worth adding for the next iteration.
Postby EViews Glenn » Wed Feb 01, 2012 4:06 pm
I believe you are correct. On both counts.
