Dear Gareth,
How can I go about estimating a system of equations on panel data? Do I go into Object(system) first where I cannot see panel window and choose GMM; or
enter into estimate equation where I can see a panel window and choose GMM but I cannot estimate a system of equations in this.
Appreciate your reply. Thanks
System of equation using panel data and gmm
EViews doesn't support panel GMM for systems.
Re: System of equation using panel data and gmm
Thanks for the quick reply. Any suggestion for software that can do this.
can you tell me why in Eviews the 3sls system estimator doesn't return a J-statistic relating to the Instruments; the GMM system estimator does this.
No theoretical reason why it can't, it just hasn't been added to the output.
Thanks for your reply. This highlightes that discriminating between different system estimators in eviews appears tricky:
FIML produces a loglik, but NLSUR doesn't.
GMM produces a J-stat, but 3sls doesn't.
Which statistical criterion/criteria would you then recommend to disriminate between estimating different nested systems a system - i.e., you estimate a system with 7 parameters and then a nested system with 5 parameters. Which one is better? The only thing i see is the Det Res Covar which i guess is part of the loglik calculation but not the full bit. I guess you could also do Wald parameter restriction estimates.
