Hello!
Im a bit stuck reproducing Stock and Watson's paper called "Vector Autoregressions". At a certain point they give the results for the root mean sqaured errors of simulated out-of-sample forecasts for inflation, unemployment and federal funds in 2 quarters, 4 quarters and 8 quarters; comparing VAR, AR and Random Walk.
I have forecast the VAR model, solving the model and obtiaining the _0 values, but do not know how to conitnue further on. Any ideas?
THanks so much!
root mean squared error of var forecast
You can use the @rmse function to calculate the rmse between any two series, in your case the forecasted values and the actual values.
Re: root mean squared error of var forecast
Is there a way to calculate minimum mean square error in Eviews ?
Many thanks
Many thanks
Not built in, but calculating it by hand shouldn't be too hard.
