Maximum Likelihood problem
coldplayer
Postby coldplayer » Wed Nov 23, 2011 5:53 am
Uploaded with ImageShack.us
trubador
Did you use forum search?
Re: Maximum Likelihood problem
Postby trubador » Wed Nov 23, 2011 8:31 am
EViews does the summation implicitly, so all you have to do is create Ldt and Lst as series and define their equations seperately. And you'll need @dnorm and @cnorm functions to do that. Your likelihood function will then be Log(Ldt + Lst). You can simply use c(1), c(2), ..., c(n) for your unknown parameters or create your own coefficient vectors. I believe, examples in the manual will guide you through the rest...
coldplayer
Postby coldplayer » Thu Dec 29, 2011 6:38 pm
Thank you for the answer. However, I've followed your advice but then I've encountered a problem. When I want to estimate a LogL object I get the message "Missing values in @logl series at current coefficients at observation.....". I've checked all series and none of them have NA in the sample period. What could be the problem? I'm attaching the workfile I'm using.
This is what I wrote in a LogL specification:
@logl lf pon=flows-(gama(1)*mmr_eur+gama(2)*yield_ger+gama(3)*ind_eu27+gama(4)*cds_cro+gama(5)*liquid_cro+gama(6)*drate_cro+gama(7)*crobex+gama(8)*resdug_cro) potr=flows-(beta(1)*cpi_cro+beta(2)*inf_cro+beta(3)*crobex+beta(4)*crbxch+beta(5)*ind_cro+beta(6)*indch_cro+beta(7)*resuvoz_cro+beta(8)*drate_cro+beta(9)*cds_cro) potraznja=(1/sigma_s(1))*(@dnorm(pon/sigma_s(1)))*(1-(@cnorm(potr/sigma_d(1)))) ponuda=(1/sigma_d(1))*(@dnorm(potr/sigma_d(1)))*(1-(@cnorm(pon/sigma_s(1)))) lf=log(potraznja+ponuda)
What am I doing wrong?
max likelihood.wf1
(56.13 KiB) Downloaded 226 times
Postby startz » Thu Dec 29, 2011 7:00 pm
Check your starting values for the parameters.
coldplayer
Postby coldplayer » Thu Dec 29, 2011 7:11 pm
Starting values are set to 0, but the problem remains if I set them to 1, 10, or any other number.
Postby startz » Thu Dec 29, 2011 8:57 pm
set the sigma values to 1000 and it'll run
coldplayer
Postby coldplayer » Fri Dec 30, 2011 3:11 am
Thanks for the help, it does work!
