Table views
MarF
Table views
Postby MarF » Sun Mar 06, 2011 9:50 am
Could someone tell me if there is a command to display table in user-specified way? What I mean, that there are visible specific number of rows and columns (for instance first 10 rows and columns). It is really annoying to extend tables every time I use them.
Thanks in advance :)
Re: Table views
Postby EViews Gareth » Sun Mar 06, 2011 10:01 am
I'm not sure I understand what you mean by this. Tables auto-extend.
MarF
Re: Table views
Postby MarF » Sun Mar 06, 2011 12:05 pm
A simple example:
... table tab1 ....'some data inputed into tab1 show tab1 ...
If you hit the run button you will see just few rows and columns of table named tab1. Is it possible to expand table in specific way by programming it?
Table views
Postby EViews Gareth » Sun Mar 06, 2011 1:01 pm
I suppose you could enter empty text into some cells if you wanted
MarF
Re: Table views
Postby MarF » Sun Mar 06, 2011 2:19 pm
It works only partially, because tables extend at the maximum for about 26 rows and 8 columns.
Re: Table views
Postby EViews Gareth » Sun Mar 06, 2011 2:24 pm
Again, I'm not really sure what you're asking. If you want a table that is bigger than 8 columns, then put something into column 9. Tables will auto-extend to whatever size you want them to be.
Jassy
Re: Table views
Postby Jassy » Sat Dec 17, 2011 8:46 am
Dear
is it is possible to switch columns in the group view
for example i have 2 time series
TMT and GDP, whenever i open as a group GDP in C1 and TMT in col2, i want to switch for the purpose of johansen cointegration test.
thanks
jassy
Table views
Postby EViews Gareth » Sat Dec 17, 2011 8:55 am
Just change to order you put them in the group.
Jassy
Re: Table views
Postby Jassy » Mon Dec 19, 2011 7:27 am
Thank you for replying But
Sorry Gareth,
i did not understand what u wrote??? :oops:
yasmine
Table views
Postby EViews Gareth » Mon Dec 19, 2011 7:53 am
The order of the columns in a group is based upon the order in which you put the series into the group.
