IOMOD
Jassy
IOMOD
Postby Jassy » Wed Nov 30, 2011 11:38 am
Hi!
I am just starting to read about Input-Output models and plan to implement it. is it possible to use Eviews for estimation methods and forecasting?
If yes, i hope :shock:
Can you please send me some reference or how to get from the users guide.
Thank you
I apprecaite your reply
Regards
Yasmine
trubador
Did you use forum search?
Re: IOMOD
Postby trubador » Thu Dec 01, 2011 6:15 am
You can carry out Input-Output analysis in any software that has matrix operation capabilities. EViews' matrix functions are quite useful for that purpose. You can also implement several RAS algorithms for updating the IO matrix. However, you cannot build more general optimization models in EViews at the moment.
Jassy
Re: IOMOD
Postby Jassy » Fri Dec 02, 2011 12:56 am
Dear trubador,
Thank you for your reply, but can you please tell me how to find some instruction about matrix use in eviews, how to input data, functions,...etc
or if you know a good applied textbokk, please write the citation.
i apprecaite your help
Thank you :)
Yasmine
trubador
Re: IOMOD
Postby trubador » Fri Dec 02, 2011 1:29 am
You should begin with http://www.eviews.com/illustrated/illustrated.html
You can also find detailed explanations in the users guide...
Jassy
Re: IOMOD
Postby Jassy » Wed Dec 07, 2011 1:35 am
Thank you
but still, i tried to search in user's guide, but it seems i am missing it.
in which chapter the detailed explaination, i'm using Eviews 7.
thank u
i appreciate yr help
Jassy
trubador
Re: IOMOD
Postby trubador » Thu Dec 08, 2011 2:35 am
Chapter 8. “Matrix Language,” on page 159 in the Command and Programming Reference.pdf
Help/Quick Help Reference/Matrix Reference in EViews will also be helpful...
Jassy
Re: IOMOD
Postby Jassy » Fri Dec 09, 2011 8:53 am
thank you :) i appreciate your support and time.
