Is there a command for exporting data from a database to a NEW workfile?
I know the fetch command works for getting data from a database to an EXISTING workfile.
The reason I'd like to do this is because I don't know the start and end dates of series in a database. When I manually export series from a database to a new workfile, Eviews will automatically detect the appropriate range to use.
I could set up a workfile with a range that is arbitrarily large (e.g. years 1800-2100) and then fetch the data. But this procedure seems a bit inefficient since I'd have a vast number of NAs.
Exporting database to new workfile
Re: Exporting database to new workfile
Unfortunately not (and it is a glaring omission).
You have to do something like:
where X is the name of the series.
%db = "c:\temp\mydb.edb"
%freq = @wquery(%db, "name=X", "freq")
%start = @wquery(%db, "name=X", "start")
%end = @wquery(%db, "name=X", "end")
wfcreate {%freq} {%start} {%end}
fetch X
