Forming a series
mjfl
Forming a series
Postby mjfl » Sat Nov 12, 2011 3:26 am
Dear Glenn, Gareth and all,
series y = z_piet1a series x = mu for !horizon= 95 to 126 smpl 1978q1 1978q1+!horizon var var{!horizon}.ls 1 3 y x smpl 1978q1+!horizon+2 1978q1+!horizon+5 var{!horizon}.fcast _f{!horizon} next smpl @all
allows me to create dynamic forecast of 4 periods for each horizon.
e.g y_f95 gives dynamic forecast for 2002q2 to 2003q1 while the rest are unchanged.
y_f96 gives 2002q3 to 2003q2 etc.
i hope to sum the values in y_f95 from 2002q2 to 2003q1 and divide by 4 before storing the value in another new series called zebra in 2002q1.
this means a sum divide and append to new series.
can u teach me how to do so using this code or another code seperately? i cant seem to find any links on extraction of value and appending it back.
thk u so much.
Re: Forming a series
Postby EViews Gareth » Sun Nov 13, 2011 4:33 pm
Not quite sure I follow, but either the @movav function will do what you want, or you can just set the sample to be those periods you want to sum over, then use @sum.
mjfl
Postby mjfl » Sun Nov 13, 2011 6:14 pm
hi gareth,
thank you so much, i got what i wanted! wow. @movav is useful.
can i ask another 2 questions on groups?
1.i have a program which i'm running with series x always changing and i need to run it over all the series in the workfile except the obvious resid and c.
is it possible to automate the process?
2. another seperate question
series y = z_piet1a series x = f_sti for !horizon= 95 to 126 smpl 1978q1 1978q1+!horizon var var{!horizon}.ls 1 4 y x
is it possible to let series x take on f_sti,d(f_sti),d(f_sti,2),log(f_sti) and dlog(f_sti) automatically in a program so that i do not have to retype and each time to generate new vars or eqns in a simialr setting?
Postby EViews Gareth » Sun Nov 13, 2011 7:20 pm
Use @wlookup to find the names of all the series in the workfile, then loop over them:
%names = @wlookup("*", "series") for %var {%names} ... next
Yes, just loop over the specifications:
%specs = "f_sti d(f_sti) d(f_sti,2) log(f_sti) dlog(f_sti)" for %var {%specs} series x = {%var} next
mjfl
Postby mjfl » Mon Nov 14, 2011 6:40 pm
hi gareth, i tried it in my setting, the 1st one worked! thank u!
the second one didnt.
how can i capture the equations in the different specification in different equations?(i will try VAR after learning this)
i mean i like an equation1 for f_sti, eqaution2 for d(f_sti) etc etc?
do you have a basic example?
can i ask 2 more questions?
1.
for !horizon= 95 to 129 smpl 1978q1 1978q1+!horizon equation eq{!horizon} for !i=0 to !maxlags for !j=0 to !maxlags eq{!horizon}.ls(cov=hac) y c x( to -!i) z( to -!j) if eq{!horizon}.@sc < !sc then !best2lag =!j !bestlag = !i !sc = eq{!horizon}.@sc endif next next
this loop allows me to choose models base on lowest sic. i know there is QLR test with certain trim and the recent baiperron test which helps to detect structural breaks.
can i in any way put in any of these test (or u could reccomend) in the loop so that it chooses first, no structural break second, lowest sic? i wish to obtain a good fit model that shows no structural break.
2. seperate issue: for a VAR
is it possible to let the 4 become an 'n' and allow 'n' to run from 1 to 20 instead?
many thks for the response. really helps.
Postby EViews Gareth » Tue Nov 15, 2011 8:49 am
create u 100 series f_sti=rnd series x = nrnd for %var "f_sti d(f_sti)" equation eq1.ls {%var} c x next
With regards to the QLR / baiperron test stuff, yes it is probably possible with a lot of coding.
create u 100 series y=nrnd series x=nrnd for !i=1 to 20 var var!i.ls 1 !i y x next
mjfl
Postby mjfl » Tue Nov 15, 2011 5:23 pm
hi Gareth,
1. gd knowing var lags can be looped. :)
2. the one with f_sti and d(f_sti) still does not work as i was hoping to get eq1: ls. y x c eq2: ls. d(y) x c etc. and then allow y to change in variable thats why i asked about
%deplist = @wlookup("a*", "series")
with the idea of fusing it myelf. how could the above be done?
3. for the QLR/BaiParron, which do u recommend me trying to code and can i call the pvalue of these tests just like the normal cases?
thk u so much. things are moving now. :)
Postby EViews Gareth » Tue Nov 15, 2011 7:09 pm
create u 100 series f_sti=rnd series x = nrnd !i=1 for %var "f_sti d(f_sti)" equation eq!i.ls {%var} c x !i=!i+1 next
mjfl
Postby mjfl » Tue Nov 15, 2011 10:34 pm
hi gareth, i think i gave u a wrong idea.
1. how can one do a multiple regression such that letting x change, eq1 is ls. y x c eq2 is ls. y d(x) eq 3 is ls. y dlog(x) etc
2. on a seperate note, if a workfile has 6 series a b f g h j, how do i create a program to create a workfile with a b f g h j d(a) d(b) d(f) d(g) d(h) d(j)? or must one genr one by one esp if there are 50 series?
thank u for the reply.
mjfl
Postby mjfl » Tue Nov 15, 2011 10:36 pm
2. on a seperate note, if a workfile has 6 series a b f g h j, how do i create a program to create a workfile (old or new is fine) with a b f g h j d(a) d(b) d(f) d(g) d(h) d(j)? or must one genr one by one esp if there are 50 series?
Forming a series
Postby EViews Gareth » Tue Nov 15, 2011 11:41 pm
Loops are loops. Just follow the same format and change the bits you need.
mjfl
Postby mjfl » Thu Nov 17, 2011 6:51 am
Dear Gareth,
i have attached anew workfile.
can i ask how could i code something so that it compares
k_baa1 with k_daa1 with k_faa1 with k_haa1 with k_jaa1 (all scalars) and find the smallest one given that i would like 1,2,3...42 instead.
i tried @wlookup with this code to call and then verbally inspect to choose the smallest scalar but it doesnt work:
%deplist = @wlookup(" *1 ", "series") for %dep {%deplist} show scalar{%dep} next
sgmasterexph1.WF1
(379.48 KiB) Downloaded 732 times
Postby EViews Gareth » Thu Nov 17, 2011 8:48 am
The second argument in the @wlookup function indicates what type of object to look for. You have it set to "series", when you're looking for scalars.
mjfl
Postby mjfl » Thu Nov 17, 2011 5:08 pm
hi gareth, my apology it doesnt work even if one sets it to scalar (it was a poor cut and paste).
can i by any chance call them so that i can only ask for the smallest scalar?
and may i also ask using wald test, can i "call" for the pvalue in the f-stat?
thk u!
Postby EViews Gareth » Thu Nov 17, 2011 5:10 pm
=@wlookup("*1", "scalar")
works for me.
http://forums.eviews.com/viewtopic.php?f=5&t=18
