Scaling Impulse Respone
alirezan321
Postby alirezan321 » Tue Mar 10, 2009 7:32 pm
Hi there,
I have a VAR model for monetary policy, I want to get the impulse response of output to exact 1 percent shock in federal fund rate. How do I do this? The normal VAR in eview, scales down the response to the standard deviation of the residuals.
Ali.
alirezan321
Re: Scaling Impulse Respone
Postby alirezan321 » Wed Mar 11, 2009 9:53 am
Any reply??
Postby startz » Wed Mar 11, 2009 10:33 am
Any reply??
Have you looked at the Impulse Definition tab?
rpn4
Postby rpn4 » Thu Mar 12, 2009 5:03 am
I share his question... In fact, Eviews offers the option of a unit shock to the residuals, but not factorized. General Impulse Responses, or Choleski decompositions, are only available for a standard error shock, not for a unit shock. Any suggestion on how to tackle this issue?
Postby EViews Glenn » Thu Mar 12, 2009 11:04 am
Any desired shocks not supported by the standard EViews settings may be obtained using a user-specifed vector or matrix.
Houda Boubaker
Postby Houda Boubaker » Thu Mar 11, 2010 11:02 am
Hey,
I have the same problem as Ali, and i want to ask him if he found a solution to scale the impulse responses. In fact EViews give a standard scale for the reponses and there is no option on it to change the scale into percentage!!!! Please I need an answer.
Thanks or all.
Houda.
nadja123
Postby nadja123 » Fri Mar 12, 2010 5:06 pm
Hey folks, if I remember well, you need to estimate your model in log differences to obtain the IRFs in percentages. But don't take this for granted, check it out first. And btw, don't worry, you'll never obtain help on such issues from the forum moderators. I myself found the VAR documentation and features quite :( ...
Houda Boubaker
Postby Houda Boubaker » Sat Mar 13, 2010 2:59 am
Hey Nadja123,
Thanks for the reply, but should we transform the variables in log difference?, means (we transform in logaritm form than we make the differenciation following the unit root stationarity test).
Houda BEN HADJ BOUBAKER
Phd Student
ISG Tunis
BESTMOD Laboratory
E-mail: Houda.benhadjboubaker@isg.rnu.tn
boubakerhouda@gmail.com
boubakerhouda2004@yahoo.fr
Phone: (+216) 22 630 818
