Estimation of exp smoothing parameters
kiber_master
Postby kiber_master » Tue Oct 11, 2011 10:10 pm
Hello!
I've got in User's Guide that exponential smoothing estimate best values for smoothing parameters by minimising SSR. What exactly method do you use? If it is grid search, is it effective? If one of nonlinear optimisation methods - does it always get the best coefficients. And I actually can't find, what value of tolerance you provide exactly in this method.
Thank you.
kiber_master
Re: Estimation of exp smoothing parameters
Postby kiber_master » Wed Oct 12, 2011 3:28 am
Well, I found the following:
"EViews uses (a version of) grid search for the exponential smoothing routine." (UG II, p.759)
So, it isn't exactly a grid search, am I right?
Postby EViews Gareth » Wed Oct 12, 2011 6:43 am
It is grid search.
kiber_master
Postby kiber_master » Wed Oct 12, 2011 10:42 pm
Thanks a lot!
kiber_master
Postby kiber_master » Wed Nov 02, 2011 9:44 pm
Sorry, but how can it be simple grid search, when I didn't get the best result putting E, E, E for Holt-Winters - Additive ?
Please, check the workfile, SSR is better for 1,0,0, not for 1,0.74,0.
expsm_autosearch.wf1
(8.71 KiB) Downloaded 261 times
Postby EViews Gareth » Thu Nov 03, 2011 7:52 am
It is a grid search. Just not a particularly good one. If you want more accurate estimates of the parameters, you might want to use the ExpSmooth Add-in that calls the R Forecast package. Although you'll have to think a little about the seasonality of your data for that.
kiber_master
Postby kiber_master » Fri Nov 11, 2011 12:08 am
And what accuracy do you provide?
Postby EViews Gareth » Fri Nov 11, 2011 8:43 am
I'm not sure I understand your question.
kiber_master
Postby kiber_master » Sat Nov 12, 2011 3:50 am
I mean, when you make a grid, what is the step? 0.01?
Postby EViews Gareth » Sat Nov 12, 2011 8:56 am
Yes.
