Can I ask for a help? I have a regression : y=c(1)*x1+c(2)*x2.
I generate x in this way:
genr x1=1
genr x2=(@trend+1)/10
How can i generate 100 such x using matrix? because I need this regression: y=c(1)*x1+c(2)*x2+...+c(100)*x100
I don't know how to do it in eviews. and what function to use..
regression
Re: regression
I am not sure what you are asking, but the following piece of code might guide you. Just copy and paste it into program window (i.e. File/New/Program).
'Define a coefficient vector
coef(100) beta
'Assign random (uniform) values to coefficents
rnd(beta)
'Define the dependent variable
series y
'Define the disturbance term
series u = 2*nrnd
'Generate a group for independent variables instead of a matrix
group indep
'Generate the first series (i.e. the constant variable)
series x1 = 1
'Add the first variable to the group
indep.add x1
'Begin generating the values of dependent variable
series y = beta(1)*x1
'Define a loop to generate other independent variables
for !i = 2 to 100
series x!i = nrnd 'You should introduce some sort of randomness to each independent variable in order to avoid multicollinearity
indep.add x!i 'Add each variable to the group
y = y + beta(!i)*x!i 'Continue to generate the values of dependent variable
'Add the disturbance term
y = y + u
'Estimate your regression
equation eq1.ls y indepRe: regression
but why when i try this code. in equation all: Std. Error t-Statistic Prob. are NA?
Re: regression
That is probably because you run out of degrees-of-freedom. Try to resize the range of your workfile and make sure the number of observations are greater than that of estimated coefficents.
Re: regression
yes, you'are right!
And another question ( I hope so it'll be last) :
obviously, my task is to show that fisher criterion distribution when Ho is true, goes to F(k-m,N-k) when degrees of freedom are increasing. So I'm generating one regression with 100 x, and another with 10. So in which one I can say dregrees o freedom is bigger?
Re: regression
Hi everyone!
I have created a group of independent variables, say x1 x2 x3 up to x150
group xs
for %i x1 x2 x3 'up to 150
xs.add {%i}
and I want o regress each one to my dependent variable, say log_spot
So I want to iterate the regression
ls log_spot c x1
ls log_spot c x2
ls log_spot c x3
ls log_spot c x150
does anyone have a clue how I can do it, not manually?????Thanks in advance!
group xs
xs.add {%i}
ls log_spot c x1
ls log_spot c x2
ls log_spot c x3
ls log_spot c x150
