hi apology is this able to be done?
i see one can make varmod poolmod etc but can the above be done?
thk u!
spool to model
Re: spool to model
No it can't, and it doesn't really make any sense. A spool can only contain tables, graphs and text objects. None of which can be put into a model.
Re: spool to model
thk u Gareth. i have been using the bvar add-in in program form.
but i realise it gives a spool and i seem not to be able to get a model of the bvar for which i can solve.
i checked the mkaemodel sub-routine code and tried to "put them together" in a logical manner but none works.
is there such a way to do so? make the model from bvar in the program language so i can solve it?
Re: spool to model
I'm not sure I follow. If you run the bvar addin, it offers you the option to make a model out of the results, which will create a model object. There is no need to do it yourself, and certainly not from the spool.
Re: spool to model
thks gareth for fast response.
i would like to solve for this model from 2000q3 to 2009q3 thereafter.
is my code but how can i make a model from this program?smpl 1990q1 2000q2
bvar(prior=2) 4 gdp ir inflation
Re: spool to model
looks like there's an "m=modelname" option.
Re: spool to model
thks gareth. my hand was gg numb. didnt see it in the doc. :)
