Stepwise rolling regression: plot of coeffiecients
jank
Postby jank » Fri Jan 23, 2009 2:51 am
I have a stepwise rolling regression. For every subsample Ican have a different number of significant parameters. It is easy to get the calculation but my question now is how I can store the coefficients ( of the different equations) so, that I am able to plot a chart for the whole time period for every single coefficient (e.g. alpha, beta 1, beta 2 etc.).
Re: Stepwise rolling regression: plot of coeffiecients
Postby EViews Gareth » Fri Jan 23, 2009 9:18 am
Unfortunately this is not possible in the stepwise routine included in EViews (the main reason being that the stepwise routines doesn't actually calculate and/or store the coefficients). However you can always write your own stepwise routine and store them.
As a guide, here is a simple manual stepwise routine I wrote a while back:
'create some data - 20 X variables and a Y variable that depends upon X11-X15. 'X variables are put into a group called XS create u 1000 rndseed 1 group xs group g for !i=1 to 20 series x!i=nrnd %name="x"+@str(!i) xs.add {%name} g.add {%name} next series y = nrnd + 3 for !i=11 to 15 y = y + !i*x{!i} next 'perform backwards stepwise regression - first run a model with all Xs, then remove Xs one at a time based upon tstat. equation e1 !tstop=5 !stop=0 while !stop=0 e1.ls y c xs !mint=10000 !removedvar=0 for !i=1 to xs.@count !currentt = @abs(e1.@tstats(!i+1)) 'note plus one is since the equation has a constant as the first variable, but we are not testing the constant if !currentt < !mint then !mint = !currentt !removedvar=!i endif next if !mint>!tstop then !stop=1 else if !removedvar>0 then %removedvarname=xs.@seriesname(!removedvar) xs.drop {%removedvarname} endif endif wend show e1 'run an automatic stepwise and see if it matches equation e2.stepls(METHOD=UNI,BTOL=5,BACK,TSTAT) y c @ g show e2
jank
Postby jank » Mon Jan 26, 2009 2:28 am
Thanks a lot for your answer. But I mean the values for the significant variable are calculated as observabe in the tables and the ones not included could simply be set to zero. Isn't there a possibility to save these values (just the ones included in the regression) and to recognize for each value to which variable it belongs. Sorry for asking again ..
Postby EViews Gareth » Mon Jan 26, 2009 9:14 am
You can use the @coefs data-member of the equation to store the chosen coefficients into a vector. If you wanted, you could then place that vector into a row/column of a matrix to store all of your "rolls" as one big matrix.
PCA
Postby PCA » Thu Aug 25, 2011 11:57 am
Could you elaborate on storing the coefficients for a stepwise regression?
I am running a very similar regression, and for example, sometimes the stepwise procedure will keep 3 explanatory variables, and sometimes it will keep 8. I think that this anomaly messes with the matrix set-up I have.
I am new to programming, so I know for a fact I am not setting up the matrix properly. Could you lend a hand?
I'm using eViews 7.
workfile riskdata_eviews q 1990q1 2011q2 'run rolling regression ' set window size !window = 20 ' set step size !step = 1 ' get size of workfile !length = @obsrange ' declare equation for estimation equation eq1 'calculate number of rolls !nrolls = @round((!length-!window)/!step) 'matrix to store coefficient estimates matrix(13,!nrolls) coefmat ' where 13 is the number of coefficients 'variable keeping track of how many rolls we've done !j=0 ' move sample !step obs at a time for !i = 1 to !length-!window+1-!step step !step !j=!j+1 ' set sample to estimation period smpl @first+!i-1 @first+!i+!window-2 ' estimate equation eq1.stepls(METHOD=step,BTOL=2,BACK,TSTAT) y c @ _10yr cpi duration gold hy_spread ig_spread m1 move oil tedspread vix yieldcurveslope 'store coefficients colplace(coefmat,eq1.@coefs,!j) next show coefmat
Postby EViews Gareth » Thu Aug 25, 2011 1:25 pm
Yeah, that's going to be problematic. From a conceptual point of view, how do you want to store the coefficients?
PCA
Postby PCA » Thu Aug 25, 2011 1:45 pm
What I would like is a column for each explanatory variable, and a row for each "regression roll".
Is there anyway to possible store each coefficient into its own vector? That way if it is excluded from the model based on t-stat or p-value, then it would just say NA for that particular regression?
Postby EViews Gareth » Thu Aug 25, 2011 2:10 pm
That's going to be very tricky, because you need to keep track of which variables were kept, and their position in the original list (i.e. if only MOVE, OIL, VIX are kept, you need to know to fill in the 9, 10, and 12th elements of the matrix).
PCA
Postby PCA » Thu Aug 25, 2011 2:26 pm
Exactly. That is why I was wondering if it is possible to store every coefficient in a separate vector. Or somehow store each equation in its own matrix, and then combine them after the fact?
Postby EViews Gareth » Thu Aug 25, 2011 2:35 pm
Sure, you can store every equation's coefficients in their own vector, just by doing something like:
vector coefs!i = eq1.@coefs
immediately after you've performed the stepls. You're going to end up with a bunch of vectors with different lengths, but it will work.
PCA
Postby PCA » Thu Aug 25, 2011 2:40 pm
Yeah, a little cumbersome, but it does works.
Ideally though, I'd like a fully filled matrix. I know you said it's very tricky, but is it even feasible you think?
Postby EViews Gareth » Thu Aug 25, 2011 2:51 pm
Currently I'm going to say no :(
Postby EViews Gareth » Thu Aug 25, 2011 3:02 pm
Actually, I take that back.
Theoretically you could do the following....
  • Use equation.@varlist to return a string containing the list of regressors that were chosen by the stepwise procedure
  • Loop through the elements of that string one at a time, and find their position in the original list of regressors using @wfind
  • Copy the coefficient associated with that regressor into the corresponding position in the original matrix
So something, very roughly, equal to:
%fullregs = "u v w y z" matrix(5, !nrolls) coefs 'after this inside your loop equation eq1.stepls y c @ {%fullregs} %chosenregs = eq1.@varlist %chosenregs = @wmid(%chosenregs, 3) 'drop off Y and C from the varlist for !n = 1 to @wcount(%chosenregs) %reg = @word(%chosenregs, !n) !nn = !n+1 'plus one because we don't care about C !coef = eq1.@coefs(!nn) %pos = @wfind(%fullregs, %reg) coefs(!i, %pos) = !coef next
PCA
Postby PCA » Thu Aug 25, 2011 3:24 pm
Still trying to work through this. It's giving me the following error:
"scalar assigned to string in "%POS = @WFIND("_10YR CPI DURATION GOLD HY_SPREAD IG_SPREAD M1 MOVE OIL TEDSPREAD VIX YIELDCURVESLOPE", "_10YR")
I'm not sure if I implemented your coding right. Still trying to decipher it a bit.
workfile riskvariables_eviews q 1990q1 2011q2 'group riskvariables 'run rolling regression ' set window size !window = 20 ' set step size !step = 1 ' get size of workfile !length = @obsrange ' declare equation for estimation equation eq2 'string of variables %fullregs = "_10yr cpi duration gold hy_spread ig_spread m1 move oil tedspread vix yieldcurveslope" 'calculate number of rolls !nrolls = @round((!length-!window)/!step) 'matrix to store coefficient estimates matrix(13,!nrolls) coefs' where 13 is the number of coefficients 'variable keeping track of how many rolls we've done !j=0 ' move sample !step obs at a time for !i = 1 to !length-!window+1-!step step !step !j=!j+1 ' set sample to estimation period smpl @first+!i-1 @first+!i+!window-2 ' estimate equation ' eq2.stepls(METHOD=UNI,BTOL=2,BACK,TSTAT) y c @ _10yr cpi duration gold hy_spread ig_spread m1 move oil tedspread vix yieldcurveslope 'after this inside your loop equation eq2.stepls(METHOD=UNI,BTOL=2,BACK,TSTAT) y c @ {%fullregs} %chosenregs = eq2.@varlist %chosenregs = @wmid(%chosenregs, 3) 'drop off Y and C from the varlist for !n = 1 to @wcount(%chosenregs) %reg = @word(%chosenregs, !n) !nn = !n+1 'plus one because we don't care about C !coef = eq2.@coefs(!nn) %pos = @wfind(%fullregs, %reg) coefs(!i, %pos) = !coef next next
PCA
Postby PCA » Thu Aug 25, 2011 3:29 pm
And actually, I need to know the constant, so does that alter the coding you provided at all?
%chosenregs = @wmid(%chosenregs, 3) 'drop off y and C from the varlist
and
