print spool will change print setup
maxchen
Postby maxchen » Thu Aug 11, 2011 1:42 am
ver: EViews7Patch_080411.exe
set the "print setup" vie File/Print setup, text/table to custom, 50%
run the following code
wfcreate u 4 genr x = @obsid spool sp01 sp01.append x sp01.append x.line
and print the spool object sp01 in EViews. Then print setup will be changed: the text/table will be change to 100%.
I have checked the EViews32.ini
before print spool
Text Scale=page
Text Scale Percent=50
after print spool
Text Scale=fixed
Re: print spool will change print setup
Postby EViews Jason » Thu Aug 11, 2011 3:04 pm
We will get it fixed ASAP.
Thanks for narrowing down the bug. You saved us a lot of time.
