BaiPerron (Bai-Perron breakpoint test - Requires R)
I guess it would be easier to make the slight modification to the add-in to fetch other values from R, than it would be to go to another language. Although that, of course, depends on your knowledge of the languages.
Re: BaiPerron (Bai-Perron breakpoint test - Requires R)
I am just starting to learn R. I've used Eviews and Stata for most of my research. I have programmed the Bai (1999) test in Stata, but wanted to see how well the BaiPerron test worked in Eviews, mainly because of the easy of Eviews. I would have no clue how to adjust the add-in.
I'm assuming you want to run the Add-in...(if not, disregard the comments below).
There is documentation in the EViews 7.1 supplement. Here's the 30 second version.
If you have EViews 7.1 and R installed on your system, go to the webpage for the Add-ins and install the Bai-Perron Add-in. If you don't have EViews 7.1 installed, do so. If you don't have R installed, see the documentation for EViews 7.1 on the steps you'll need to follow to install and configure R.
Estimate your equation in EViews, then use the Proc/Add-ins menu to call your routine.
Hi, i just finished to run the B&P test (it give me two break in the data), but i want to see the diferent coefficients for the variables....How can i see them?
Diego
Diego
I guess, run the regression by itself over the smaller subsamples.
Ok, yes i did that but i thought there was another way to see it in the test. ThanksI guess, run the regression by itself over the smaller subsamples.
I'm able to run the add-in but the statistics reported are nearly useless when presenting results. I have no come across a paper citing Bai-Perron without reporting the F statistics. Is there a 30 second guide for going into the add in and capturing the F statistics
I'm not sure what you mean by the F-statistics. The R package that we use, strucchange, does have a routine for calculating F-statistics, but they're just the collection of Chow breakpoint Wald F-statistics that can be calculated in EViews via the Quandt-Andrews test built into EViews.
That helps. Thanks.
I have used the Bai-Perron addin before and it have worked fine. Therefore I know for a fact that I am not missing anything on my computer, the only problem should be in my code below. I have updated to the latest versions of R, EViews 7.2, the addin, the package strucchange.
I have attached the file that I am using. What am I doing wrong, it has worked before with similar tasks but not this time. I really cannot understand why.
WFOPEN "C:\temp\y.wf1"
'just to make sure that the NAs are not the problem
smpl 29/06/2009 @last
equation eq01.ls y10 c x10 (x10*dx10)
'equation eq01.ls y10 c x10 'THIS DID NOT WORK EITHER
'equation eq01.ls y10 c @trend 'THIS DID NOT WORK EITHER
show eq01
eq01.BAIPERRON(size = 0.15)
copy table01 hello
- y.wf1
- (27.67 KiB) Downloaded 1078 times
The first specification won't work because you'll get too many singularities. The second specification worked fine for me.
Why can't the test be used on ARMA terms?
I believe the R package doesn't support it.
It doesn't. The standard algorithms for computing all of the regressions in a Bai-Perron framework requires simple linearity of the specification.
Hi. I am new to eviews. I have to find the breakpoint date on stock data. I have downloaded eviews 7.1 and created my workfile with my two variables "date" and "closingprices". I downloaded R as required. I have run my regression test using the "estimate equation" option. I obtained the result window however when i click on Bai perron breakpoint test under Addin. It asked for a subsample size in which i entered the total no of observations of my sample. But when i click Ok, an error message appears stating that i havent installed R and advises to review the documentation regarding installation. I looked at the pdfs under help section but couldnt find any. What should i do to run the test?
