Saving a graph to use as a template
gilbesa
Postby gilbesa » Fri Jul 22, 2011 1:50 pm
I've made a grouped graph on two axes and would like to save the layout as a template to apply for other analysis (so I don't have to set it up another 50 times). I've gone through the documentation and see that it is possible, but I cannot find where in the software to do it. I've saved the group (icon with a G), but not the graph. Can you help? I'm using eViews 7.2.
Re: Saving a graph to use as a template
Postby EViews Gareth » Fri Jul 22, 2011 1:56 pm
Create a named graph object with the settings you want (green icon with a little bar chart on it). Then hit the Template button. Then Manager Templates. Then add that graph to the predefined templates list.
