title error in mgarch's garch output
maxchen
Postby maxchen » Sat Jun 04, 2011 6:43 pm
ver: EViews7Patch_060211.exe
try the following example
%ex7 = "\Example Files\EV7 Manual Data\" %ch31 = "Chapter 31 - System Estimation" %wf = @evpath + %ex7 +%ch31 +"\fx.wf1" wfopen %wf system sys01 sys01.append dlog(jy) = c(1) sys01.append dlog(sf) = c(2) sys01.append dlog(bp) = c(3) smpl 1980 2000 freeze(tbdv) sys01.arch(deriv=aa,showopts) @diagvech c(indef) arch(1,indef) garch(1,indef) freeze(g_cor) sys01.garch(cor) 'correlation typo on the output fig as covariance
the last line, the output figure titled as "conditional covariance", not correlation. however, using point and click, it is fine.
Re: title error in mgarch's garch output
Postby EViews Gareth » Fri Jun 10, 2011 9:52 am
Will be fixed in next patch.
maxchen
Postby maxchen » Tue Jun 14, 2011 11:43 pm
Ver: EViews7Patch_061311.exe, the title bug has been fixed, however for asymmetry term, there may be a typo in the output and representations in Covariance specification part
freeze(tb01) sys01.arch @diagvech c(fullrank) arch(1,fullrank) garch(1,fullrank) tarch(1,fullrank) freeze(txt01) sys01.representations
the Covariance specification says
GARCH = M + A1.*RESID(-1)*RESID(-1)' + D1.*(RESID(-1)*(RESID(-1)<0))
*(RESID(-1)*(RESID(-1)<0))'D1.*(RESID(-1)*(RESID(-1)<0))
*(RESID(-1)*(RESID(-1)<0))' + B1.*GARCH(-1)
it seems that the tarch term has been duplicated.
maxchen
Postby maxchen » Thu Jun 16, 2011 6:30 pm
another bug
sys01.makeloglike slk sys01.makeloglike slk2 'error if comment inline
the first line work, however, the second line errors, if the comment is removed, it is OK.
maxchen
Postby maxchen » Sun Jun 19, 2011 6:23 am
one more
sys01.correl(12,factor=cov)
will generate the same graph as sys01.correl(12)
if using point and click, it is fine.
