It is hard to deny that the competition is very tough and I am getting mocked by my colleagues for using EViews (I work at a department of Economics and Statistics). Some softwares have almost died by the competition such as Gauss and other programs.dare i ask: is stata better than eviews?
The R-project is a free software that in the end will win over all its competitors unless EViews is able to fully integrate the routines from R into EViews. Then I mean that the programmers at EViews must make it easy for EViews' users to borrow every routine from R so that it can be inserted into the EViews code (e.g. in simulations). My prediction is that EViews and Stata will slowly die in the end if this integration between the programs is not accomplished. I know that version 7 is taking that a first step in that direction, but I would like to see a user-friendly tutorial for how to implement every routine from R into EViews (not only the 1 or 2 that can be downloaded from EViews' web page). Right now it seems a little bit complicated if this even can be done.
If you compare EViews and Stata, my subjective view is that EViews is much more user-friendly, and this is why I use it for my courses that I teach (Econometrics 1 and 2 and Time-series analysis).
Moreover, this EViews forum with extremely competent support staff is also an advantage of EViews.
Basically all my senior colleagues have swapped to R since there are no limitations. Since it is free it will continue to grow. However, if the routines could be integrated (by simultaneously running R) together with EViews then EViews is a software that can actually benefit from the progress of R. If this is not done (that is integrating R), free softwares such as R (not very user-friendly but infinitely flexible and lots of canned routines), Gretl (user-friendly but not flexible... can be used for teaching) and maybe even J-Multi will take a piece of the pie from EViews. Even if R is not as user-friendly as EViews, the students can use R at home and can also use R for free at any working place after graduation. Therefore it should be important for EViews to get into as many schools as possible since then the students will continue to use EViews even after graduation.
I had planned to drop EViews and start investing time in R, but when I bought version 7 I could see a first (but not a sufficient) step of integrating the routines of R into EViews, so I will give EViews some more time and see what happens.
(If my subjective discussion about competitors is inappropriate in this forum, I do not mind if the moderators remove my message before people read it)
To the moderators: please state what the future plans are for EViews 7 and 8 regarding integrating R routines into EViews. When I say integrated routines I will just like to call an R-routine, not open a menu. It would be important to know since then it will also be easier to convince the rest of the school that we should use EViews in the future too. Some teachers thinks that we should use a free software instead. I am very happy with EViews, but I need some more arguments for convincing the rest of the department that we should stick with EViews for the future.
Best wishes,
P
