HP filter - storing the cycle component
javiersan
Postby javiersan » Thu Feb 19, 2009 10:18 am
The menu-based HP filter option allows for storing the cycle and filtered component. I cannot find on the help how to store the cycle component via the program command (i.e. gdp.hpf(lambda=1600) gdp_hp will only store the trend). Could you please help me with this?
I tried to replicate the stored cycle series by applying a formula like: cycle = series / trend - 1 or cycle=(series - trend) / series, where series is the original time series data and trend is the hp-filtered series. I get nothing similar to the cycle calculated by EViews. Where am I going wrong?
Thanks,
Javier
Re: HP filter - storing the cycle component
Postby EViews Gareth » Thu Feb 19, 2009 10:28 am
I don't believe it is possible to store the cycle series via command.
Postby startz » Thu Feb 19, 2009 12:00 pm
Thanks,
Javier
Try
gdp.hpf(lambda=1600) gdp_hp series gdp_c = gdp - gdp_hp
javiersan
Postby javiersan » Thu Feb 19, 2009 3:33 pm
Oh! that was easy!
Thanks.
flourence
Postby flourence » Tue Nov 28, 2017 10:36 pm
Can i use hodrick prescott to show if the series has a trend or none ?
