Quick Question on Equation Data Members
Lucas.mateo.gomez
Postby Lucas.mateo.gomez » Mon Jun 06, 2011 9:32 pm
Hi everybody
I'm currently estimating an ARCH model using two different error distribution assumptions:
- Generalized Error (GED)
- Student's t
When on the estimation window I don't fix the value of the parameters (GED's r, T's v), instead I let Eviews find them for me.
I would like to know if there's any equation data member (e.g. @aic, @hacbw, @coefs..) that holds the value of each parameter whenever I use a given distribution assumption. I've been over the documentation several times but I haven't found any pointers and I wanted to check with the forum before starting a table scheme for data extraction.
By the way I'm using Eviews v.7.1
Thanks in advance, regards.
Lucas
Re: Quick Question on Equation Data Members
Postby EViews Gareth » Mon Jun 06, 2011 9:37 pm
It is stored in the @coefs, along with all the other parameter estimates.
Lucas.mateo.gomez
Postby Lucas.mateo.gomez » Mon Jun 06, 2011 9:47 pm
Thanks Gareth, I appreciate it. I was actually revisiting that option a few minutes ago, found out it was there all the time.
Best,
Lucas
