I have a problem in using replacement variables for the path in the run command.
If I run this piece of code, it gives out an error:
%dir = "C:/TestE_Views/testcode"
run {%dir}
but equivalently the following code runs fine
run "C:/TestE_Views/testcode"
What am I doing wrong?
Is there a workaround this?
Any help is greatly appreciated!
thank you!
Using Replacement variables
Re: Using Replacement variables
%dir = "c:/temp/test"
run {%dir}
