Equation forecasting command with range
rdbms
Postby rdbms » Mon Feb 16, 2009 6:18 pm
In the command line, if I want to specify the range for forecast sample, how can I specify it? For example, I can key in Forecast sample = 81 81 in the forecast dialog box, how can I do it using parameter for the command: eq.forecast ser01f?
Thanks,
Sunny
Re: Equation forecasting command with range
Postby EViews Gareth » Mon Feb 16, 2009 8:55 pm
smpl 81 81
eq.forecast ser01f
