Hallo,
I want to use the @dtoo command in a pool. Is this possible? (I only get error messages :( )
Context: I want to calculate the growth rate log(Y_2008) - log(Y_1950) in a pool (gdp series for different countries in the sample 1950 - 2008). In order to do the calculations I tried to get the value of the series in 2008 with the @dtoo command. However, this seems to be not possible in a pool... Does someone knows another way to solve this?
My code:
pool all _ALB _DZA _AGO _ARG
all.genr grow? = log(y_?(@dtoo("2008"))) - log(y_?(@dtoo("1950")))
Thanks!
@dtoo in a pool
Re: @dtoo in a pool
You can't use @dtoo to directly index a series like that (whether in a pool or not).
Try this:
Try this:
!o1 = @dtoo("2008")
!o2 = @dtoo("1950")
all.genr grow? = log(y_?(!o1)) - log(y_?(!o2))
Re: @dtoo in a pool
Thanks for the help.
Unfortunately, this does not solve my problem, as EViews calculates for example grow_usa = log(y_usa(59)) - log(y_usa(1)) and this is always "NA". (I suppose, that it always takes the 59 lead which does not exist)
I think I will try to solve my calculations without the pool and make a big loop (for %a _ALB _DZA _AGO _ARG) ...
However, I really appreciate the quike responses in this forum!!
Re: @dtoo in a pool
My mistake. You're probably best off just using a for loop.
!o1 = @dtoo("2008")
!o2 = @dtoo("1950")
for %j _ALB _DZA _AGO _ARG
%name = "y" + %j
!num = log({%name}(!01)) - log({%name}(!02))
%name2 = "grow" + %j
series {%name2} = !num
