predetermined intercept/coefficients?
asjp
Postby asjp » Fri Feb 13, 2009 1:35 pm
I'm trying to run an OLS model where one of the data sets in the equation is supposed to be the intercept - or with a coefficient of one..
However no matter what I've tried I can't remember for the life of me if it's possible to set the coefficient for this as one and then run the regression estimation?
Thank you
Re: predetermined intercept/coefficients?
Postby startz » Fri Feb 13, 2009 1:57 pm
Thank you
If you had
ls y c x1 x2
and knew the coefficient for x1 equaled 1, you could run instead
ls y-x1 c x2
being sure there is no space in "y-x1"
Postby EViews Glenn » Fri Feb 13, 2009 2:17 pm
Or put the left-hand-side variable expression in parentheses:
ls (y - x1) c x2
