equations = app.Lookup("*","equation",1)
For Each equation In equations
command = "freeze(mode=overwrite,script_temp_fe) " & equation & ".effects"
app.Run(command)
command = "script_temp_fe.save " & output & "\\Effects\\" & equation & ".effects"
app.Run(command)
but if one of them does not then the script crashes with an error message
is there a way by which I can check if any kind of effects exist with the equation before executing the freeze commandEquation does not contain this type of fixed or random effects
OR
some way in which i can override the error message and the script continues with the next equation
-Thanks
Ravi
