Hi there,
I am having a bug with the command "pagesave2 on Eviews 7. I am trying to save some data from Eviews to an excel file.
Upon running the following lines:
%xlsfile = "X:\Equi_Val_Exc_G10\source_modeles_structurel.xlsx"
pagesave(t=excelxml) {%xlsfile} range="facmod" @keep sig_* @smpl 1990m01 @last
I get the following message:
EViews library error: 'Writing Excel (*.xlsx) files is currently not supported' in "PAGESAVE(T=EXCELXML) X:\EQUI_VAL_EXC_G10\SO ...
This is because my excel file is being deleted from its folder when the command is run. Why would that happen?
Thanks for your help,
Mara
problem with the command "pagesave" - Eviews 7
maragloria
Re: problem with the command "pagesave" - Eviews 7
This isn't a bug. Rather it is exactly as the error message indicates - EViews will not save xlsx files.
maragloria
But why is the file being deleted when the code runs?
maragloria
I have another question about the command pagesave. I'm gonna post it in the forum related to programming.
Thanks in advance.
Thanks in advance.
