Com Automation, VB Script, System Objects
Ravi
Postby Ravi » Fri Apr 29, 2011 6:46 am
I am using EViews COM automation in order to invoke EViews from a VB script.
I am using the script to extract the residuals of a system object.
for that I have the following lines in my script
equations = app.Lookup("*","system",1) For Each equation In equations command = "" & equation & ".makeresids script_temp" app.Run(command) command = "freeze(mode=overwrite,script_temp2) script_temp" app.Run(command) command = "script_temp2.save " & C:\\Work\\ACT_FIX_RES\\" & equation & ".makeresid" app.Run(command) next
However I Get the following error,
EViews.Application.1.Run: SCRIPT_TEMP is not a series in "DO_ SYST_OBJ1.MAKERESIDS SCRIPT_TEMP
SYST_OBJ1 is the first system object in my eviews work file.
I am still a beginner at eviews so pardon me if I have misused any terms
Version : Eviews 7
-Ravi
Re: Com Automation, VB Script, System Objects
Postby EViews Gareth » Fri Apr 29, 2011 7:52 am
Try doing:
directly in EViews, rather than through COM.
Ravi
Postby Ravi » Fri Apr 29, 2011 10:46 am
A pop up titled Make Residuals pops up
with options for ordinary,cholesky of covariance,square root of covariance and square root of corelation pops up.
When i select ordinary and select OK , I do get the residual series.
Why is it not working from COM? any Ideas?
Postby EViews Gareth » Fri Apr 29, 2011 10:57 am
Our COM guy is not in today. I'll make sure he takes a look on Monday though.
Ravi
Postby Ravi » Tue May 03, 2011 4:03 am
Hi Gareth,
Any Updates?
Postby EViews Steve » Tue May 03, 2011 8:05 am
I just ran a small test of your code sample, and with some slight changes for formatting, it worked for me just fine. Here's my code sample (I ran this under Excel 2007).
Sub test() On Error GoTo ErrorHandler Dim mgr As New EViews.Manager Dim app As EViews.Application Dim command As String 'on my desktop, I already had EViews with a workfile already open... Set app = mgr.GetApplication(ExistingOnly) equations = app.Lookup("*", "system", 1) For Each equation In equations command = "" & equation & ".makeresids script_temp" Call app.Run(command) command = "freeze(mode=overwrite,script_temp2) script_temp" Call app.Run(command) 'You don't need to double-up the backslashes when it's in a VBA string... command = "script_temp2.save C:\files\" & equation & ".makeresid" Call app.Run(command) Next ErrorHandler: Set app = Nothing Set mgr = Nothing End Sub
If this code fails for you at the same place (for your workfile), please send me a copy of the workfile to steve@eviews.com.
Ravi
Postby Ravi » Wed May 04, 2011 10:51 am
Hi Steve,
Thanks for your help.
I will try out your script soon and get back with the results
Also if it helps you debug I am running the script as extract.vbs and executing it along cscript.exe and my eviews version in 7.2
Postby EViews Steve » Wed May 04, 2011 12:51 pm
As long as you're not running on a 64-bit OS, my code sample should be fine to be run from a VBS script...
