multiple dependent variables
gregjackson05
Eviews 6; I'm trying to run multiple regressions at once. I have about 1000 mutual fund companies and about 3 years of monthly returns.
I have tried OPEN - as SYSTEM but this only seems to allow me to run 30 - 50 regressions.
Is there a way to run all at once??
Cheers Greg
Cheers Greg
Re: multiple dependent variables
Do you need to estimate them simultaneously from a theoretical point of view, or from a easy-of-use point of view? If the latter, you're probably best off writing a simple program that will estimate them all.
gregjackson05
Hi Gareth,
Yeah I just want the quickest option, for both ends (sorting output and results).
Simple program sounds good, but I would not know where to start??
Greg
Greg
gregjackson05
Hi any help on top of the intro to programming would be appreciated.
I'm a little lost with the examples that use 'nrnd'.
My example is no doubt typical - list of companies and returns; regressed on a couple of constant independent variables.
how do I create my dependent variable???
Thanks Greg
Thanks Greg
I'm not sure I understand your question. Surely you already have dependent variables and do not need to create them at all?
gregjackson05
yes I have a list of companies and their returns that are my dependents.
I'm struggling for the terminology to explain.....
lots of dependent variables - 3 constant independents.
Greg
Greg
So just write a loop that loops through your dependent variables, regressing each one. Something like:
Where dep1, dep2, dep3 and dep4 are your dependent variables, and x1 x2 x3 are your independent.
for %dep dep1 dep2 dep3 dep4
equation eq{%dep}.ls {%dep} c x1 x2 x3
gregjackson05
Thanks, can I just cut and paste my company names into %dep ??
Greg
Greg
gregjackson05
I've tried to copy your instructions but getting "flow of control statement..."
I appreciate any help.
Greg
Greg
EViews programming code needs to be written in EViews programs. Click on File->New Program.
Perhaps you should read the programming chapter of the EViews Command and Programming Reference.
gregjackson05
nevermind got it!
gregjackson05
sorry didn't see your last post, yeah that was my mistake
Thanks Greg
Thanks Greg
gregjackson05
Hi, just when I thought I was there now I'm faced with maximum line length error. What is max. number of dependent variables allowed? I have tried reducing my dependent name size to shorten command line??
Cheers Greg
Cheers Greg
Run it through more than one loop then.
for %dep dep100 dep101 dep102 dep103
