string variable used in path reference
eviewsnew
Postby eviewsnew » Fri Apr 22, 2011 4:25 pm
I'm trying to use a string variable to indicate the directory path for opening a file. But it doesn't work. But if i specify the whole path clearly and without the string variable, it works.
Can you help?
Is there any good reference book for Eviews programming for beginner?
thanks!
works:wfopen \\sac-psas-01\econ\riskindex\RI_V3.1\data\2011Q1\ur_nsa_eviews.csv
doesn't work:
%dir="2011Q1"
wfopen \\sac-psas-01\econ\riskindex\RI_V3.1\data\%dir\ur_nsa_eviews.csv
Re: string variable used in path reference
Postby EViews Gareth » Fri Apr 22, 2011 10:02 pm
Try:
%dir="2011Q1" wfopen \\sac-psas-01\econ\riskindex\RI_V3.1\data\{%dir}\ur_nsa_eviews.csv
eviewsnew
Postby eviewsnew » Mon Apr 25, 2011 10:48 am
Yes it works this way. thanks!
is there a good book to recommend about these programming rules?
Try:
Postby EViews Gareth » Mon Apr 25, 2011 12:18 pm
Only the Command and Programming Reference, and what you can pick up by reading this forum.
