Exporting Series with Illegal Names?
paues
Postby paues » Thu Apr 21, 2011 1:18 am
Is there a way to export .tsd files containing series with names that do not conform with EViews naming restrictions (e.g. "illegal names")?
I am trying to export series from Aremos to EViews and then back again to Aremos. And Aremos allows many more characters in series names (e.g. @, £ and %).
Best,
Fredrik
EViews Chris
Re: Exporting Series with Illegal Names?
Postby EViews Chris » Thu Apr 21, 2011 9:53 am
I assume you're accessing the TSD file as a database (eg. using the 'dbopen' command), and that you're currently using the 'store' command to export the series?
If you need to rename during a store operation, you need to use the 'copy' command. eg.
dbopen mydb
copy x__ mydb::x@%%
You could also store the series with the EViews name, then do a rename after you've written the series to the database
dbopen mydb
store x
rename mydb::x x@%%
Hope that helps.
Chris
