CanCor (Canonical Correlations)
Postby EViews Gareth » Thu Jul 08, 2010 2:39 pm
This thread is about the CanCor add-in that calculates canonical correlations between two group objects.
JHaltmaier
Re: CanCor (Canonical Correlations)
Postby JHaltmaier » Wed Mar 30, 2011 8:23 am
When I try to run CanCor I get an error message saying that !COLS is not defined or is an illegal command.
Postby EViews Gareth » Wed Mar 30, 2011 8:38 am
Could you provide the workfile you're using?
JHaltmaier
Postby JHaltmaier » Wed Mar 30, 2011 10:08 am
I can't because it contains confidential data. However, I have tried to use cancor in several different workfiles and with different groups and I always get the response that !COLS is not defined or is an illegal command, which seems to be a programming problem. Is that in fact an EVIEWS command? I can't find it in the command reference. Do you have workfiles in which cancor works? Maybe you could send one to me. Thanks.
Postby EViews Gareth » Wed Mar 30, 2011 10:34 am
If I run the following program to generate a workfile, then run the CanCor add-in, using GY and GX as the two groups, it works fine:
rndseed 1 create u 100 series x1=nrnd series x2=nrnd series y1=nrnd series y2=nrnd group gx x1 x2 group gy y1 y2
JHaltmaier
Postby JHaltmaier » Wed Mar 30, 2011 11:19 am
I copied and pasted your program, ran it to create a workfile, tried to use CanCor and got exactly the same error message: !COLS is not defined or is an illegal command.
JHaltmaier
Postby JHaltmaier » Wed Mar 30, 2011 11:24 am
I also just discovered that it is creating tables called cancorr, cancorr01, etc. (apparently a new one every time I try to run it) that are empty.
Postby EViews Gareth » Wed Mar 30, 2011 11:25 am
What's the build date of your copy of EViews (help->about eviews)?
JHaltmaier
Postby JHaltmaier » Wed Mar 30, 2011 12:21 pm
April 20 2010
Postby EViews Gareth » Wed Mar 30, 2011 12:23 pm
Ouch, nearly a year out of date. You should update it (help->EViews update).
Return to “Add-in Support”
