BVARs yet again
donihue
BVARs yet again
Postby donihue » Sun Mar 20, 2011 8:34 am
I apologise for once again returning to this subject!
The GUI works perfectly, but I am having problems using the command-line interface for this excellent Add-in (I want to use a loop to calculate a range of models over different sets of hyperparameters).
According to the .pdf file for this Add-in, the command line should read (as an example) "bvar(Prior=0) gdp interest inflation", with other options available, such as L0, L1, etc
I have tried
bvar(Prior=0) mb gdp usd_rate cpi
bvar(Prior=0,L0=0.8,L1=0.1,L3=2,L4=1,L5=0.07,Mu5=0.1,Mu6=0.1,QM=12) mb gdp usd_rate cpi
bvar(Prior=0 L0=0.8 L1=0.1 L3=2 L4=1 L5=0.07 Mu5=0.1 Mu6=0.1 QM=12) mb gdp usd_rate cpi
bvar(Prior=0,lambda0=0.8,lambda1=0.1,lambda3=2,lambda4=1,mu5=0.1,mu6=0.1,qm=12) mb gdp usd_rate cpi
but in all cases, received the cryptic message "Syntax error".
This clearly indicates that I am doing something obviously wrong in formulating the command, but I cannot see what. Can you help, please?
Regards
Donihue
EViews Esther
Re: BVARs yet again
Postby EViews Esther » Tue Mar 22, 2011 11:50 am
It was my bad. The first argument should be the number of lags.
For example, you can say:
bvar(Prior=0) 2 mb gdp usd_rate cpi
(Note: "bvar(Prior=0) mb gdp usd_rate cpi" will report the error message :cry: ).
When you re-install the BVAR addin, you will see the updated command options.
donihue
Re: BVARs yet again
Postby donihue » Wed Mar 23, 2011 2:57 am
Many thanks, Esther - it works fine now
regards
Donihue
donihue
Re: BVARs yet again (2)
Postby donihue » Wed Mar 23, 2011 3:17 am
Hello again, Esther,
Any chance of adding a command-line option to produce a model, as in the GUI?
Given the lack of a direct forecast command for BVARs (as also for VECMs) this is essential for forecasting.
Again, many thanks for your work on this Add-in: it is a real life-saver for we BVAR workers!
Regards
Donihue
mayxanh
Re: BVARs yet again
Postby mayxanh » Sat Apr 02, 2011 7:27 pm
Hi Esther,
I have just installed BVAR and use the exact command that you shown above. However, there is an error message keeping poping up: "_SH01 is not defined" Could you please to explain me why? Thank you very much.
T
EViews Esther
Re: BVARs yet again
Postby EViews Esther » Mon Apr 04, 2011 8:11 am
It seems that there exist a singularity problem. Could you upload your workfile? Then, I will figure out the solution.
mayxanh
Re: BVARs yet again
Postby mayxanh » Mon Apr 04, 2011 7:44 pm
Esther,
Thank you for your assistance. I upload the workfile named test.
When I run the following command:
bvar(Prior=0) 2 LOG_IRR_SA_CA LOG_CCLI_S IR_SPREAD_U LOG_GDP_CHN_SA LOG_CPI_TOTAL_S LOG_CERI_S
The error message is "_SH01 is not defined"
When I run the command:
bvar(Prior=0,m=model) 2 LOG_IRR_SA_CA D(LOG_CCLI_S) D(IR_SPREAD_U) D(LOG_GDP_CHN_SA) D(LOG_CPI_TOTAL_S) D(LOG_CERI_S)
(because all series are non-stationary, except LOG_IRR_SA_CA)
then the model is estimated without any error message. However, there are a series of error messages inside the model object:
"syntax error in ..."
I need to get the model object in order to do the forecasting using rolling windows.
Thank you again
test.WF1
(18.03 KiB) Downloaded 1265 times
EViews Esther
Re: BVARs yet again
Postby EViews Esther » Tue Apr 05, 2011 10:52 am
Let me clarify the problem first. Since the given regressors are perfectly collinear, the prior values for the residual covariance cannot be calculated.
Following the paper (Sims and Zha; 1998), the current addin calculates the diagonal elements of the prior for the residual covariance matrix S (see Equation 10 in the documentation) by OLS steps.
For example, the 1st diagonal element of S for the 1st lag of LOG_CCLI_S is derived by
!m = 3 'number of variables matrix(!m,!m) S 'storage for S equation EQ1.ls D(LOG_CCLI_S) D(LOG_CCLI_S)(-1) c 'Do OLS: LOG_CCLI_S on D(LOG_CCLI_S)(-1) and c only. !SSR = EQ01.@ssr s(1,1) = !SSR/EQ1.@regobs
When you have perfect collinearity problem in OLS steps, the prior for the residual covariance cannot be calculated.
I think that the solution to your problem can be resolved by changing the prior calculation steps. For example,
equation EQ1.ls LOG_IRR_SA_CA D(LOG_CCLI_S) D(IR_SPREAD_U) D(LOG_GDP_CHN_SA) D(LOG_CPI_TOTAL_S) D(LOG_CERI_S) c 'Do OLS: all regressors are used matrix S = EQ1.@coefcov
mayxanh
Re: BVARs yet again
Postby mayxanh » Tue Apr 05, 2011 8:24 pm
Hi Esther,
Thank you for your explanation. Regarding the problem with the makemodel, I find out that the problem arise from the usage of D(x)(-1) as the variable so that the @word function does not return the correct word. It first returns D(x) then (-1) instead of returning the whole string D(x)(-1).
I wrote a fix for the subroutine eqmake and this time it works perfectly.
subroutine local eqmake(string %spec, string %coefs, string %speceq)
%speceq = ""
!start = 1
!length = @LENGTH(%spec)
!end = 1
for !i=1 to @wcount(%coefs)
'%word = @word(%spec,!i)
!end = @INSTR (%spec, " ", !i)
if !end =0 or !end = !length then
!end = !length + 1
endif
!size = !end - !start
%word = @MID(%spec, !start, !size)
if @upper(%word) = "C" then 'constant
%word = ""
endif
%coef = @word(%coefs,!i)
if @val(@word(%coefs,!i))>=0 then
%speceq = %speceq+"+"+%coef+"*"+%word
else
%coef=@right(%coef,@len(%coef)-1)
%speceq = %speceq+"-"+%coef+"*"+%word
endif
!start = !end + 1
if @val(@word(%coefs,1))>=0 then
%speceq = @right(%speceq,@len(%speceq)-1)
endif
%speceq = @left(%speceq,@len(%speceq)-1)
endsub
mayxanh
Re: BVARs yet again
Postby mayxanh » Tue Apr 05, 2011 8:55 pm
Hi Esther,
Another question I would like to ask is how to select the lag length for a BVAR? In a VAR system, we can use Information criterion to automatically select the lag length. How's about BVAR?
Thank you
Re: BVARs yet again
Postby EViews Gareth » Wed Apr 06, 2011 8:08 am
That's a little outside of the realm of technical support.
mayxanh
Re: BVARs yet again
Postby mayxanh » Thu Apr 07, 2011 5:25 am
Hi Gareth, Esther,
Thanks a lot for your help. Another question I would like to ask is that you use OLS to estimate the BVAR? The VAR system is also estimated by OLS? Thanks again.
BVARs yet again
Postby EViews Gareth » Thu Apr 07, 2011 6:52 am
No. The BVAR uses Bayesian techniques, as outlined in the documentation.
mjfl
Re: BVARs yet again
Postby mjfl » Fri Aug 26, 2011 2:17 am
hi,
im new to BVAR and would like to ask if there is any command to forecast the bvar?
i see that making the model helps but can someone pls enlighten how to forecast the bvar directly or from the model?
i cant understand what is
1) no of forecast period
2) forecast selection
becasue even after trying with or w/o it my workfile remains same without any forecast. pls help as im really trying to learn and though the query sound really silly.
Re: BVARs yet again
Postby EViews Gareth » Fri Aug 26, 2011 7:58 am
Once you have the model, just solve the model over the period you wish to forecast.
Return to “Add-in Support”
