Error in estimations
marcounam
Postby marcounam » Tue Mar 15, 2011 7:51 am
Hello!
I hope someone can help me regarding the following issue : Yesterday i ran 20 regressions on the same dependent variable with 20 different independent variables, then i realized that the series that was my dependent variable on the 20 regressions was not the one i wanted. What i would like to avoid is having to do the 20 regressions all over again with the new dependent variable. Is there a way to do this, or more generally what is the best solution to this problem?
Thanks a lot for time in advance.
Re: Error in estimations
Postby EViews Gareth » Tue Mar 15, 2011 7:53 am
If you ran the regressions manually, then you'll have to re-do them manually. If you wrote a program to do them, you'll just have to modify your program.
