hello all
i have been trying to find some code enabling me to save a program into more than one location after it had finished running, but unfortunately have not met with much success
what i'm looking for is akin to the line of code used to save graphs
i.e. graph_name.save(options) [path\]file_name
Thank you in advance for your help
Wes
command for Saving a program.
Re: command for Saving a program.
There is no command that will tell a program to save itself (I can't think of a use for such a thing).
However, you could always use the shell command to tell Windows to make a copy of the program etc..
Thank you Gareth
the reason I though up of using such a command is in order to save any one programme into different locations without having to do it manually.
this way - i can share the latest copy of the programmes i write with my colleagues in the most efficient way.
if ever the decision is made to make such a line of code available to users, i would be very happy :O)
cheers & thank you for the response.
Wes
Wes
