Hello, I'm using Eviews7.
I am currently doing some MLE estimation using a logl object. Apparently convregence depends strongly on the starting values of the parameters. In programming the estimation procedure, I'm using the statement parm c(1) 0 c(2) 1 etc.
I'd like to also store the starting values I'm using in my output. Any ideas how I can handle that? Thanks.
stroring starting values
Re: stroring starting values
The LOGL estimation command has a showopt option that will print the starting values out in the estimation output.
I'm trying to solve my LOGL object consecutively for differing starting values right now. Is there a command I could use in my program, telling to delete an LOGL object, if it does not converge? (or if there comes the warning - near singular cov matrix and I get NAs for standard errors). This would be really helpful in automating the search...
Unfortunately there is no way to get that information back, other than freezing the estimation output into a table, then searching for the terms you want to test.
You can test whether the standard errors of the coefficients are [edit] NA and then conditionally delete the object
Is there a way to obtain e.g. a standard error of one of the coefficients estimated in the logl?
If so, I could use an if-statement of the form
if SE = "NA" delete LOGL
would that be possible?
Yes, although that won't help you with convergence not achieved.
if logl.@stderrs(1) = na then
d logl
endif
thanks! That helps - if I let the program run for different starting values I won't have to sort out the ones that didn't converge by hand ...
Is there a way to get access to the p-value of a coefficient? I'd like to automatically delete estimation results with a very bad p-value.
I didn't find anything in the manual... thanks!
Nope, they have to be computed manually from the t-stat.
