Hi all...
I have problems in constructing constrained VAR. After estimating the unrestricted VAR, I would like to set its certain coefficients to zero and then translate them to impulse response function to compare the effect with the baseline VAR (unconstrained one), but I haven't found any possible way to do that yet.
Perhaps is there any useful suggestion?
I'd really appreciate your help in this matter... thank's a lot :)
How to constraint estimated VAR coefficient to zero?
Re: How to constraint estimated VAR coefficient to zero?
Don't see a good way ... The VAR object doesn't allow constrained VAR estimation. System object can estimate coefficient constrained equations, but System can't generate impulse responses.I have problems in constructing constrained VAR. After estimating the unrestricted VAR, I would like to set its certain coefficients to zero and then translate them to impulse response function to compare the effect with the baseline VAR (unconstrained one), but I haven't found any possible way to do that yet.
