stacked bar interpretation
Here's a group and the resulting stacked bar graph
Can someone explain how the picture is a sensible representation of the data. (This may not be a bug, but it's not looking like a good feature either.)
Re: stacked bar interpretation
How would you rather it looked?
Hey, why do I have to do the hard questions??? Something like. A from 0.5 to -0.5, B from -.5 to -2.5, F from -2.5 to, uh, I dunno. But what does the picture I get mean?
It is just as it says it does - each series is stacked. A goes first, and is blue, and goes from 0 to 1. Then B goes on top, and goes from 1 to 3 (1+2=3). Then F goes on top of that and goes, in green, from 3 to 0.5 (3+-2.5=0.5).
Okay, not a bug. But when are you going to implement the "do what I want-not what I said" command?
If you go into the graph dialog, then Graph Elements, then Bar-Area-Pie, then check the box that says "Stack positive & negative....", you might get something more to your liking.
Thanks.
modelmaker
Is there a corresponding command option for stacking positive and negative values separately?
Graphname.option +/-stackposneg
modelmaker
I gave it a try, but I get an "Invalid graph option" error. What could I be doing wrong?
(Also, I'm using EViews 7.)
What, exactly, did you type?
modelmaker
Oh wait, I realize what I did wrong. I just entered exactly what you typed without thinking. "Graphname.options +stackposneg" works just fine. Thanks!
