_ character
javiersan
_ character
Postby javiersan » Wed Feb 09, 2011 5:45 pm
I am trying to rename series x as _. When I write "rename x _" eviews seems to wait for additional information as if the _ was for continuing the command in an additional line. This didn't happen before the latest patch, how can I disable it?
Thanks,
Javier
Re: _ character
Postby EViews Gareth » Fri Feb 11, 2011 9:42 am
This seems to work for me:
create u 100 series x1=nrnd rename x1 _
javiersan
Re: _ character
Postby javiersan » Fri Feb 11, 2011 10:11 am
It seems to work in the program but not in the command editor.
Thanks,
Javier
Re: _ character
Postby EViews Gareth » Fri Feb 11, 2011 10:16 am
We'll look into it.
Re: _ character
Postby EViews Gareth » Fri Feb 11, 2011 11:19 am
I don't think we can do much about this due to the line continuation feature. There is a work-around:
string tmp = "_" rename z1 {tmp} d tmp
Turns out my program was a bit of a red-herring. If you have lines of code after the rename, it also won't work. You can also get around that via:
%tmp= "_" rename z1 {%tmp}
Not the most attractive work around...
