dlog(x,y,z) returns NAs
nupogodi
Postby nupogodi » Thu Feb 03, 2011 6:30 am
am i wrong in something??
wfcreate(wf=test,page=sht1) m 1998m1 2012m12 %a="myseries" series {%a} = rnd+2 'this line works fine series {%a} = log({%a}) 'this line works fine series {%a} = d({%a},0,12) 'BUG! returns NAs, but should return values series {%a} = dlog({%a},0,12) 'BUG! returns NAs, but should return values
Re: dlog(x,y,z) returns NAs
Postby startz » Thu Feb 03, 2011 8:52 am
There are two things going on here.
First, you are getting some NA's because you are asking for a difference where the lagged term starts before the data range. As an example, if you say
dlog(x,1)
then your smpl needs to be set to begin with the second observation or later.
Second, there appears to be a bug in EView where the differencing operator equals zero. EViews acts, incorrectly, as if the argument equaled 1.
Postby EViews Gareth » Thu Feb 03, 2011 8:56 am
Startz:
d(x,0,1) is not the same as d(x,1,1).
However, you are right that d(x,0)=d(x,1) in EViews. Perhaps this is a bug, but it isn't a big one :D
Postby startz » Thu Feb 03, 2011 9:29 am
Startz:
Right, separate issues.
It's only a bug in the sense that EViews produces the wrong answer.
Postby EViews Gareth » Thu Feb 03, 2011 11:28 am
True, it is just that is it completely unrelated to the initial post/question :D
The reason the user is getting NAs is because, as you pointed out, the difference doesn't exist for the first observation, which is not a bug at all.
