I can't fetch objects from database by typing commands in command area, while I can do the same by using Fetch on the toolbar of the workfile. Eviews doesn't seem to recognize the file extention name edb.
The following is what I typed in commend area:
fetch "c:\program files (x86)\eviews6\example files\ev6 manual data\chapter 17 - eviews programming\progdemo.edb": : hsf
When entered, the following error message pops up:
PROGDEMO.EDB": is an illegal or reserved object name. Enter a name to be used in EViews.
I have EViews 6 and Windows 7 for operating system.
Thank you.
fetching object from database
Re: fetching object from database
Remove the spaces you have at the end.
fetch "c:\program files (x86)\eviews6\example files\ev6 manual data\chapter 17 - eviews programming\progdemo.edb"::hsf
