Hi everyone,
I am trying to find a procedure to find peaks and troughs dates in a time series with eviews.
It should be something like the Bry and Boschan routine which i found but only in Rats and it would take me quite a bit of time to reproduce in eviews.
Has anyone already dealt with this problem?
M.
Peak and trough dates
Re: Peak and trough dates
I'm not familiar with that paper, but is the following not a solution?
Regards,
Javier
'With y the original data series
'Finds maxima
series max = @recode(y>y(-1) and y>y(+1),y,na)
'Finds minima
series min= @recode(y<y(-1) and y<y(+1),y,na)
Javier
I think that will do, it was so easy!
thanks a LOT!
m.
thanks a LOT!
m.
Bry-Boschan routine is a non-parametric Business Cycle Dating Algorithm that identifies peaks and troughs. The code above, as noted by javiersan, only finds maxima and minima and therefore should not be considered as a substitute.
