Hausman test and dummy variables
odovakar
Postby odovakar » Thu Jan 22, 2009 4:14 pm
I need help with two things that have been partly answered before on the board. First: I have an unbalanced panel and a fixed effects model in log-log form. How do I conduct an "ordinary" Hausman test in order to see if the chosen specification is correct? Is there some kind of command for it? In Stata this seems to be a piece of a cake, where a single command instantly provides you with P values and all, but I haven't been able to figure out how to do the same in Eviews 5.0.
Second, I have approximately the same problem as another guy who wrote here, i.e. I need to include a column of dummy variables (1 and 0) in the panel, but every time I do this I get the "Near singular matrix" error. Is there some way to get around this obstacle?
Thanks in advance!
Re: Hausman test and dummy variables
Postby EViews Glenn » Thu Jan 22, 2009 4:34 pm
For the first question. Just estimate the random effects equivalent, then use the Fixed/Random effects Hausman test view...
As to the second issue, the deep issue relates to what your dummy variables are meant to represent. There is clearly a singularity going on here that is directly related to the fixed effects. If there are variables that do not vary within cross-sections, then they are not identified in the fixed effects framework.
odovakar
Postby odovakar » Sat Jan 24, 2009 11:51 am
Thanks. As for the Hausman effect again - just one, stupid question: How do you do that exactly? :oops:
Which settings do I need to use in Eviews for the random effects equivalent? In other words: Are there any specific ones that I need in order for the test to work?
After I have done this: Where do you choose the Hausman test view from?
Postby EViews Glenn » Mon Jan 26, 2009 11:45 am
In the cross-section effects (I'm assuming you have cross-section effects) setting of the estimation dialog, select Random instead of Fixed.
All of the random effects methods (which are on the options) page are valid for Hausman test comparisons.
