Hi.
I just wonder if there is an unconditional GO TO type of command that allows the program to run from a certain line.
The reason is that, suppose I have a thousand lines in my program, and I want to run only from line 200 to 300.
I can "comment selection" from 1 to line 199 and from 301 to the end. But as the entire program is long, it becomes difficult.
So is there a command that runs only a block of the entire program?
Thank you in advance.
Liu.
How to skip part of the program?
Re: How to skip part of the program?
Unfortunately not. You'd have to either use if then endif statements, or comments, or just copy and paste that part to another program.
Thanks for your answer!
