Postby BradleyMorris » Thu Dec 30, 2010 2:25 am
maybe my initial intention was not correct. I am not sure whether I want Eviews to treat several variables as 1 variable, but I want to be able to assess the difference of the influence of 1 independent variable (sentiment) on the dependent variable (return), after controlling for different firm characteristics.
So what I want to do for example:
test whether the returns of small and big firms are differently influenced by sentiment. The fashion in which the prior research did this, is with the multiple regression formula I denoted earlier, with the interaction variable. They first test whether the interaction coefficient is significantly different from zero. Then they view the coefficient of the characteristic to say whether or not the influence differs across different groups (small vs big firms).
I just realized that one option to solve this might be to select only three variables: the return(dependent),1 group of firm characteristics (instead of all in one), say small firms, and then sentiment (2nd independent) and finally to add the interaction variable.. Thereafter I could run the same analysis, but this time with big firms and then compare the differences. Do you think this would work? Or is there a more efficient way of sorting, so I don't have to run several different regressions?
-But-if I would do this, I would have to know how to determine whether the difference of the influence of sentiment across big vs small firms is significant.. Would you by any chance know about this too?
I hope my situation has become more clear, if not, don't hesitate to comment, I'm very glad of the possibility of help.
