Ordered dependent variable creation
Joanne
Postby Joanne » Tue Jun 22, 2010 12:03 pm
Hi all
I am running an ordered probit model with panel data and my dependent variable is the credit ratings of banks. I know that they need to be in integer form, eg 1, 2, 3 which would correspond with C, C/B and B for example but I am not sure how to create that series. Can anyone help? Thanks
Re: Ordered dependent variable creation
Postby EViews Gareth » Tue Jun 22, 2010 12:12 pm
Obviously hard to say without knowing what form your data is in, but something like:
smpl if rating="C" series ordered = 1 smpl if rating = "C/B" ordered = 2 smpl if rating = "B" ordered = 3
Will do what you want.
You might also be able to use a value map.
Joanne
Postby Joanne » Wed Jun 23, 2010 4:03 am
Thanks so much, it worked!
bg2010
Postby bg2010 » Mon Dec 13, 2010 5:34 am
Dear Joanne, I hav just seen your post, since you are trying to do the same thing as I want. How is it actually possible to do a panel estimation AND an ordered dependent variable regression at the same time. In the estimation dialog I have to decide between either one of them. Hence, if I do the orderered dep. variable thing, I can't choose fixed effects anymore (which I want!)
Thanks, best!
Nils
